In scripting you should not rely on saved sites, use this command instead
We need to remove this response (below) from sftp output during our transfers from version 5.13.5, please.
What parameter or patch can do this?
Reason: This output advice-message response is causing confusion when reviewing logs with our auditors when running our jobs.
Your help is appreciate.
-Keith
Example output:
In scripting you should not rely on saved sites, use this command instead:
open sftp://mdlive:***@sftp-uat.gbophb.org/ -hostkey="ssh-rsa 1536 QB7AnCdt
-Keith
Example output:
