can't delete certain items in folders
Re: can't delete certain items in folders
Can you delete that file using any other SFTP client?
Do you have any suggestions?
MeesterGijs
Nederland
Because the first thing we need to determine, is whether this is a client- or a server-side problem.
Ok, get it. Yes, I was able to delete the folder with filezilla. So what does that mean?
So can you please post verbose logs files both from FileZilla and WinSCP showing an attempt to delete the same file? Btw, is it always the same file(s)? Or does it happen with random files?
MeesterGijs
Yes, it is the same file or the same files that I want to delete. Doens't work wiht WinSCP (huge fan!) but does work with Filezila.
What are verbose logs? How do I get those?
