Drive Selection has no effect and does not switch to the selected drive as expected
BerndWetzel
When I try to select a mounted drive using the "drive drop-down list", WinSCP does not switch to that remote drive, but instead shows me my c:\windows\system32 folder. This is true for some of my network drives, but curiously not for all.
I'm using WinSCP 5.13.5 on Win7 64bit Enterprise.
Keep up the good work!
Bernd
Description: GIF animation showing the erroneous behavior
Re: Drive Selection has no effect and does not switch to the selected drive as expected
