Error handling and Powershell
Darkstar
UK
Good Afternoon,
I am new to the world of WINSCP and Powershell.
In have written a script to get some files from a server, that works well. However I am trying to capture a success/fail parameter.
I am running the below command, if anyone know how to script testing for success or fail. I would be grateful.
Receive-WinSCPItem -localpath $localpath -RemotePath /users21/test/test.csv
Thank you
Richard
Re: Error handling and Powershell
Receive-WinSCPItem is a cmdlet from WinSCP PowerShell Wrapper Module
https://github.com/tomohulk/WinSCP
So please ask there.
Though I assume you can handle its errors as with any other PowerShell cmdlet.
Google for "powershell handle errors".
See for example the try ... catch construct used in all WinSCP .NET assembly PowerShell (not WinSCP PowerShell Wrapper Module) examples:
https://winscp.net/eng/docs/library_powershell#example
