WinSCP Could not retrieve directory listing
Hi Someone help. I am trying to establish a connection to FTP server using WinSCP via Proxy. Host is using dynamic IP and i cant allow the IP address in the firewall. So the method i use is proxy & Passive mode. It keep giving me this Could not retrieve directory listing. Filezilla works fine.
Here's some logs:-
> 2018-12-04 10:42:46.499 PASS *******
< 2018-12-04 10:42:46.561 230 Logged on
> 2018-12-04 10:42:46.561 SYST
< 2018-12-04 10:42:46.608 215 UNIX emulated by FileZilla
> 2018-12-04 10:42:46.608 FEAT
< 2018-12-04 10:42:46.671 211-Features:
< 2018-12-04 10:42:46.671 MDTM
< 2018-12-04 10:42:46.671 REST STREAM
< 2018-12-04 10:42:46.671 SIZE
< 2018-12-04 10:42:46.671 MLST type*;size*;modify*;
< 2018-12-04 10:42:46.671 MLSD
< 2018-12-04 10:42:46.671 UTF8
< 2018-12-04 10:42:46.671 CLNT
< 2018-12-04 10:42:46.671 MFMT
< 2018-12-04 10:42:46.671 EPSV
< 2018-12-04 10:42:46.671 EPRT
< 2018-12-04 10:42:46.671 211 End
. 2018-12-04 10:42:46.686 Connected
. 2018-12-04 10:42:46.686 Doing startup conversation with host.
> 2018-12-04 10:42:46.749 PWD
< 2018-12-04 10:42:46.795 257 "/" is current directory.
. 2018-12-04 10:42:46.811 Getting current directory name.
. 2018-12-04 10:42:46.998 Retrieving directory listing...
> 2018-12-04 10:42:46.998 TYPE A
< 2018-12-04 10:42:46.998 200 Type set to A
> 2018-12-04 10:42:46.998 PASV
. 2018-12-04 10:43:01.288 Timeout detected.
. 2018-12-04 10:43:01.288 Could not retrieve directory listing
* 2018-12-04 10:43:01.475 (EFatal) Lost connection.
* 2018-12-04 10:43:01.475 Timeout detected.
* 2018-12-04 10:43:01.475 Could not retrieve directory listing
* 2018-12-04 10:43:01.475 Type set to A
* 2018-12-04 10:43:01.475 Error listing directory '/'.
Here's some logs:-
