Local list is blue color
Re: Local list is blue color
WinSCP shows compressed files in blue (and always did). Didn't you enable file compression for your local files recently?
mic537
Yes. You hit the point. Somehow this folder turned out to be commpressed by windows. Color of files became black after I removed compress propety of folders and files. Thank you.
Allrange
Is it possible to leave the compression on but disabling the color formating in WinSCP, so it shows compressed and uncompressed files the same way?
There's no such configuration option unfortunately.
