Cannot get real path for '.'.
bpbiszkopt
i trying to solve why i can't chroot user in sftp.
ChrootDirecotory has chmod 755, chown to root.
But when i trying to connect by winscp i have
No such file or directory.
Error code: 2
Error message from server: No such file
If i disable option chrootdirecotry winscp connects successfully to this folder.
Server-sftp log
debug1: user owsmerf matched 'User owsmerf' at line 119
debug3: match found
debug3: reprocess config:120 setting ChrootDirectory /mnt/test
debug3: reprocess config:121 setting PasswordAuthentication yes
debug3: reprocess config:122 setting X11Forwarding no
debug3: reprocess config:125 setting AllowTcpForwarding no
debug3: reprocess config:126 setting ForceCommand internal-sftp
debug3: mm_answer_pwnamallow: sending MONITOR_ANS_PWNAM: 1
debug3: mm_request_send entering: type 9
debug2: monitor_read: 8 used once, disabling now
debug2: input_userauth_request: setting up authctxt for owsmerf [preauth]
debug3: mm_inform_authserv entering [preauth]
debug3: mm_request_send entering: type 4 [preauth]
debug2: input_userauth_request: try method none [preauth]
debug3: userauth_finish: failure partial=0 next methods="publickey,password,keyboard-interactive" [preauth]
debug3: send packet: type 51 [preauth]
debug3: receive packet: type 50 [preauth]
debug1: userauth-request for user owsmerf service ssh-connection method keyboard-interactive [preauth]
debug1: attempt 1 failures 0 [preauth]
debug2: input_userauth_request: try method keyboard-interactive [preauth]
debug1: keyboard-interactive devs  [preauth]
debug1: auth2_challenge: user=owsmerf devs= [preauth]
debug1: kbdint_alloc: devices '' [preauth]
debug2: auth2_challenge_start: devices  [preauth]
debug3: mm_request_receive entering
debug3: monitor_read: checking request 4
debug3: mm_answer_authserv: service=ssh-connection, style=
debug2: monitor_read: 4 used once, disabling now
debug1: userauth-request for user owsmerf service ssh-connection method password [preauth]
debug1: attempt 2 failures 1 [preauth]
debug2: input_userauth_request: try method password [preauth]
debug3: mm_auth_password entering [preauth]
debug3: mm_request_send entering: type 12 [preauth]
debug3: mm_auth_password: waiting for MONITOR_ANS_AUTHPASSWORD [preauth]
debug3: mm_request_receive_expect entering: type 13 [preauth]
debug3: mm_request_receive entering [preauth]
debug3: monitor_read: checking request 12
Could not get shadow information for owsmerf
debug3: mm_answer_authpassword: sending result 1
debug3: mm_request_send entering: type 13
Accepted password
debug1: monitor_child_preauth: owsmerf has been authenticated by privileged process
debug3: mm_get_keystate: Waiting for new keys
debug3: mm_request_receive_expect entering: type 26
debug3: mm_get_keystate: GOT new keys
debug3: mm_auth_password: user authenticated [preauth]
debug3: send packet: type 52 [preauth]
debug3: mm_request_send entering: type 26 [preauth]
debug3: mm_send_keystate: Finished sending state [preauth]
debug1: monitor_read_log: child log fd closed
debug3: ssh_sandbox_parent_finish: finished
User child is on pid 19645
debug3: safely_chroot: checking '/'
debug3: safely_chroot: checking '/mnt/'
debug3: safely_chroot: checking '/mnt/test'
Changed root directory to "/mnt/test"
debug1: permanently_set_uid: 1000/10008
debug3: monitor_apply_keystate: packet_set_state
debug2: set_newkeys: mode 0
debug1: rekey after 4294967296 blocks
debug2: set_newkeys: mode 1
debug1: ssh_packet_set_postauth: called
debug3: ssh_packet_set_state: done
debug3: notify_hostkeys: key 0: ssh-rsa SHA256:fUCEN7nIrhjB4hmBaZGCAazs8NhjFZAng7FJq+ULwN4
debug3: notify_hostkeys: key 2: ecdsa-sha2-nistp256 SHA256:C+e/6VekhNNLipwaQ7TxyHe2sHBiTZHFfv32rDjoxuA
debug3: notify_hostkeys: key 3: ssh-ed25519 SHA256:vPqw2xS04KMzAxxhUp716p536qhBatXpYucv9R3fgQE
debug3: notify_hostkeys: sent 3 hostkeys
debug3: send packet: type 80
debug1: Entering interactive session for SSH2.
debug2: fd 5 setting O_NONBLOCK
debug2: fd 6 setting O_NONBLOCK
debug1: server_init_dispatch
debug3: receive packet: type 2
debug3: Received SSH2_MSG_IGNORE
debug3: receive packet: type 90
debug1: server_input_channel_open: ctype session rchan 256 win 2147483647 max 16384
debug1: input_session_request
debug1: channel 0: new [server-session]
debug2: session_new: allocate (allocated 0 max 2)
debug3: session_unused: session id 0 unused
debug1: session_new: session 0
debug1: session_open: channel 0
debug1: session_open: session 0: link with channel 0
debug1: server_input_channel_open: confirm session
debug3: send packet: type 91
debug3: receive packet: type 98
debug1: server_input_channel_req: channel 0 request simple@putty.projects.tartarus.org reply 0
debug1: session_by_channel: session 0 channel 0
debug1: session_input_channel_req: session 0 req simple@putty.projects.tartarus.org
debug1: server_input_channel_req: channel 0 request subsystem reply 1
debug1: session_input_channel_req: session 0 req subsystem
debug2: subsystem request for sftp by user owsmerf
debug1: subsystem: internal-sftp
Starting session: forced-command (config) 'internal-sftp'
debug2: fd 3 setting TCP_NODELAY
debug3: ssh_packet_set_tos: set IP_TOS 0x08
debug2: fd 9 setting O_NONBLOCK
debug2: fd 8 setting O_NONBLOCK
debug2: fd 11 setting O_NONBLOCK
debug3: send packet: type 99
debug2: channel 0: read 13 from efd 11
debug3: channel 0: discard efd
Winscp-log
. 2018-12-11 09:44:17.352 Session name: sftp_route (Modified site)
. 2018-12-11 09:44:17.352 Host name:
. 2018-12-11 09:44:17.352 User name: owsmerf (Password: No, Key file: No, Passphrase: No)
. 2018-12-11 09:44:17.352 Tunnel: No
. 2018-12-11 09:44:17.352 Transfer Protocol: SFTP (SCP)
. 2018-12-11 09:44:17.352 Ping type: Off, Ping interval: 30 sec; Timeout: 15 sec
. 2018-12-11 09:44:17.352 Disable Nagle: No
. 2018-12-11 09:44:17.352 Proxy: None
. 2018-12-11 09:44:17.352 Send buffer: 262144
. 2018-12-11 09:44:17.352 SSH protocol version: 2; Compression: No
. 2018-12-11 09:44:17.352 Bypass authentication: No
. 2018-12-11 09:44:17.352 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: Yes
. 2018-12-11 09:44:17.352 GSSAPI: Forwarding: No; Libs: gssapi32,sspi,custom; Custom:
. 2018-12-11 09:44:17.352 Ciphers: aes,chacha20,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2018-12-11 09:44:17.352 KEX: ecdh,dh-gex-sha1,dh-group14-sha1,rsa,WARN,dh-group1-sha1
. 2018-12-11 09:44:17.352 SSH Bugs: Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto
. 2018-12-11 09:44:17.352 Simple channel: Yes
. 2018-12-11 09:44:17.352 Return code variable: Autodetect; Lookup user groups: Auto
. 2018-12-11 09:44:17.352 Shell: default
. 2018-12-11 09:44:17.352 EOL: LF, UTF: Auto
. 2018-12-11 09:44:17.352 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes; Follow directory symlinks: No
. 2018-12-11 09:44:17.352 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2018-12-11 09:44:17.352 SFTP Bugs: Auto,Auto
. 2018-12-11 09:44:17.352 SFTP Server: default
. 2018-12-11 09:44:17.352 Local directory: C:\Users\Documents, Remote directory: /, Update: Yes, Cache: Yes
. 2018-12-11 09:44:17.352 Cache directory changes: Yes, Permanent: Yes
. 2018-12-11 09:44:17.352 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2018-12-11 09:44:17.352 DST mode: Unix
. 2018-12-11 09:44:17.352 --------------------------------------------------------------------------
. 2018-12-11 09:44:17.415 Selecting events 63 for socket 1172
. 2018-12-11 09:44:17.415 We claim version: SSH-2.0-WinSCP_release_5.13.5
. 2018-12-11 09:44:17.430 Waiting for the server to continue with the initialization
. 2018-12-11 09:44:17.430 Looking for incoming data
. 2018-12-11 09:44:17.430 Looking for network events
. 2018-12-11 09:44:17.430 Detected network event
. 2018-12-11 09:44:17.430 Enumerating network events for socket 1172
. 2018-12-11 09:44:17.430 Enumerated 18 network events making 18 cumulative events for socket 1172
. 2018-12-11 09:44:17.430 Handling network write event on socket 1172 with error 0
. 2018-12-11 09:44:17.430 Handling network connect event on socket 1172 with error 0
. 2018-12-11 09:44:17.493 Detected network event
. 2018-12-11 09:44:17.493 Enumerating network events for socket 1172
. 2018-12-11 09:44:17.493 Enumerated 1 network events making 1 cumulative events for socket 1172
. 2018-12-11 09:44:17.493 Handling network read event on socket 1172 with error 0
. 2018-12-11 09:44:17.493 Server version: SSH-2.0-OpenSSH_7.4
. 2018-12-11 09:44:17.493 Using SSH protocol version 2
. 2018-12-11 09:44:17.493 Waiting for the server to continue with the initialization
. 2018-12-11 09:44:17.493 Looking for incoming data
. 2018-12-11 09:44:17.493 Looking for network events
. 2018-12-11 09:44:17.508 Detected network event
. 2018-12-11 09:44:17.508 Enumerating network events for socket 1172
. 2018-12-11 09:44:17.508 Enumerated 1 network events making 1 cumulative events for socket 1172
. 2018-12-11 09:44:17.508 Handling network read event on socket 1172 with error 0
. 2018-12-11 09:44:17.508 Doing ECDH key exchange with curve Curve25519 and hash SHA-256
. 2018-12-11 09:44:17.539 Waiting for the server to continue with the initialization
. 2018-12-11 09:44:17.539 Looking for incoming data
. 2018-12-11 09:44:17.539 Looking for network events
. 2018-12-11 09:44:17.711 Detected network event
. 2018-12-11 09:44:17.711 Enumerating network events for socket 1172
. 2018-12-11 09:44:17.711 Enumerated 1 network events making 1 cumulative events for socket 1172
. 2018-12-11 09:44:17.711 Handling network read event on socket 1172 with error 0
. 2018-12-11 09:44:18.320 Server also has ecdsa-sha2-nistp256/ssh-rsa host keys, but we don't know any of them
. 2018-12-11 09:44:18.320 Host key fingerprint is:
. 2018-12-11 09:44:18.320 ssh-ed25519 256 b4:15:b4:57:07:e3:dc:55:d5:54:55:cf:62:be:d7:8e vPqw2xS04KMzAxxhUp716p536qhBatXpYucv9R3fgQE=
. 2018-12-11 09:44:18.320 Verifying host key ssh-ed25519 0x26cb968db233e315 2c8e09d7d2739f8c ec8b360be1b2e86c ae35973c3077b36a ,0x58f14e9b9b1ad1f9 9334b26a1e261629 c79d7036deeec422 f2723bc6b6a75fb8  with fingerprints ssh-ed25519 256 b4:15:b4:57:07:e3:dc:55:d5:54:55:cf:62:be:d7:8e vPqw2xS04KMzAxxhUp716p536qhBatXpYucv9R3fgQE=
. 2018-12-11 09:44:18.367 Asking user:
. 2018-12-11 09:44:18.367 **Continue connecting to an unknown server and add its host key to a cache?**
. 2018-12-11 09:44:18.367 The server's host key was not found in the cache. You have no guarantee that the server is the computer you think it is.
. 2018-12-11 09:44:18.367 The server's Ed25519 key details are:
. 2018-12-11 09:44:18.367     Algorithm:   ssh-ed25519 256
. 2018-12-11 09:44:18.367     SHA-256:   vPqw2xS04KMzAxxhUp716p536qhBatXpYucv9R3fgQE=
. 2018-12-11 09:44:18.367     MD5:   b4:15:b4:57:07:e3:dc:55:d5:54:55:cf:62:be:d7:8e
. 2018-12-11 09:44:18.367 If you trust this host, press Yes. To connect without adding host key to the cache, press No. To abandon the connection press Cancel. ()
. 2018-12-11 09:44:20.338 Selecting events 63 for socket 1172
. 2018-12-11 09:44:20.338 Initialised AES-256 SDCTR client->server encryption
. 2018-12-11 09:44:20.338 Initialised HMAC-SHA-256 client->server MAC algorithm
. 2018-12-11 09:44:20.338 Initialised AES-256 SDCTR server->client encryption
. 2018-12-11 09:44:20.338 Initialised HMAC-SHA-256 server->client MAC algorithm
. 2018-12-11 09:44:20.338 Waiting for the server to continue with the initialization
. 2018-12-11 09:44:20.338 Looking for incoming data
. 2018-12-11 09:44:20.338 Looking for network events
. 2018-12-11 09:44:20.338 Detected network event
. 2018-12-11 09:44:20.338 Enumerating network events for socket 1172
. 2018-12-11 09:44:20.338 Enumerated 1 network events making 1 cumulative events for socket 1172
. 2018-12-11 09:44:20.338 Handling network read event on socket 1172 with error 0
. 2018-12-11 09:44:20.338 Pageant is running. Requesting keys.
. 2018-12-11 09:44:20.338 Pageant has 0 SSH-2 keys
! 2018-12-11 09:44:20.338 Using username "owsmerf".
. 2018-12-11 09:44:20.353 Waiting for the server to continue with the initialization
. 2018-12-11 09:44:20.353 Looking for incoming data
. 2018-12-11 09:44:20.353 Looking for network events
. 2018-12-11 09:44:20.353 Detected network event
. 2018-12-11 09:44:20.353 Enumerating network events for socket 1172
. 2018-12-11 09:44:20.353 Enumerated 1 network events making 1 cumulative events for socket 1172
. 2018-12-11 09:44:20.353 Handling network read event on socket 1172 with error 0
. 2018-12-11 09:44:20.353 Server offered these authentication methods: publickey,password,keyboard-interactive
. 2018-12-11 09:44:20.353 Attempting keyboard-interactive authentication
. 2018-12-11 09:44:20.369 Enumerated 1 network events making 1 cumulative events for socket 1172
. 2018-12-11 09:44:20.369 Handling network read event on socket 1172 with error 0
. 2018-12-11 09:44:20.369 Server refused keyboard-interactive authentication
. 2018-12-11 09:44:20.369 Server offered these authentication methods: publickey,password,keyboard-interactive
. 2018-12-11 09:44:20.369 Prompt (password, "SSH password", <no instructions>, "&Password: ")
. 2018-12-11 09:44:22.670 Sent password
. 2018-12-11 09:44:22.670 Waiting for the server to continue with the initialization
. 2018-12-11 09:44:22.670 Looking for incoming data
. 2018-12-11 09:44:22.670 Looking for network events
. 2018-12-11 09:44:22.686 Detected network event
. 2018-12-11 09:44:22.686 Enumerating network events for socket 1172
. 2018-12-11 09:44:22.686 Enumerated 1 network events making 1 cumulative events for socket 1172
. 2018-12-11 09:44:22.686 Handling network read event on socket 1172 with error 0
. 2018-12-11 09:44:22.686 Access granted
. 2018-12-11 09:44:22.686 Opening session as main channel
. 2018-12-11 09:44:22.686 Waiting for the server to continue with the initialization
. 2018-12-11 09:44:22.686 Looking for incoming data
. 2018-12-11 09:44:22.686 Looking for network events
. 2018-12-11 09:44:22.717 Detected network event
. 2018-12-11 09:44:22.717 Enumerating network events for socket 1172
. 2018-12-11 09:44:22.717 Enumerated 1 network events making 1 cumulative events for socket 1172
. 2018-12-11 09:44:22.717 Handling network read event on socket 1172 with error 0
. 2018-12-11 09:44:22.717 Waiting for the server to continue with the initialization
. 2018-12-11 09:44:22.717 Looking for incoming data
. 2018-12-11 09:44:22.717 Looking for network events
. 2018-12-11 09:44:22.921 Detected network event
. 2018-12-11 09:44:22.921 Enumerating network events for socket 1172
. 2018-12-11 09:44:22.921 Enumerated 1 network events making 1 cumulative events for socket 1172
. 2018-12-11 09:44:22.921 Handling network read event on socket 1172 with error 0
. 2018-12-11 09:44:22.921 Opened main channel
. 2018-12-11 09:44:22.921 Waiting for the server to continue with the initialization
. 2018-12-11 09:44:22.921 Looking for incoming data
. 2018-12-11 09:44:22.921 Looking for network events
. 2018-12-11 09:44:22.952 Detected network event
. 2018-12-11 09:44:22.952 Enumerating network events for socket 1172
. 2018-12-11 09:44:22.952 Enumerated 1 network events making 1 cumulative events for socket 1172
. 2018-12-11 09:44:22.952 Handling network read event on socket 1172 with error 0
. 2018-12-11 09:44:22.952 Started a shell/command
. 2018-12-11 09:44:22.983 --------------------------------------------------------------------------
. 2018-12-11 09:44:22.983 Using SFTP protocol.
. 2018-12-11 09:44:22.983 Doing startup conversation with host.
. 2018-12-11 09:44:22.983 Session upkeep
. 2018-12-11 09:44:22.983 Looking for network events
. 2018-12-11 09:44:22.983 Timeout waiting for network events
> 2018-12-11 09:44:22.999 Type: SSH_FXP_INIT, Size: 5, Number: -1
> 2018-12-11 09:44:22.999 01,00,00,00,06,
. 2018-12-11 09:44:22.999 Sent 9 bytes
. 2018-12-11 09:44:22.999 There are 0 bytes remaining in the send buffer
. 2018-12-11 09:44:22.999 Looking for network events
. 2018-12-11 09:44:22.999 Timeout waiting for network events
. 2018-12-11 09:44:22.999 Waiting for another 4 bytes
. 2018-12-11 09:44:22.999 Looking for incoming data
. 2018-12-11 09:44:22.999 Detected network event
. 2018-12-11 09:44:22.999 Enumerating network events for socket 1172
. 2018-12-11 09:44:22.999 Enumerated 1 network events making 1 cumulative events for socket 1172
. 2018-12-11 09:44:22.999 Handling network read event on socket 1172 with error 0
. 2018-12-11 09:44:22.999 Received 154 bytes (0)
. 2018-12-11 09:44:22.999 Read 4 bytes (150 pending)
. 2018-12-11 09:44:22.999 Read 150 bytes (0 pending)
< 2018-12-11 09:44:22.999 Type: SSH_FXP_VERSION, Size: 150, Number: -1
< 2018-12-11 09:44:22.999 02,00,00,00,03,00,00,00,18,70,6F,73,69,78,2D,72,65,6E,61,6D,65,40,6F,70,65,
< 2018-12-11 09:44:22.999 6E,73,73,68,2E,63,6F,6D,00,00,00,01,31,00,00,00,13,73,74,61,74,76,66,73,40,
< 2018-12-11 09:44:22.999 6F,70,65,6E,73,73,68,2E,63,6F,6D,00,00,00,01,32,00,00,00,14,66,73,74,61,74,
< 2018-12-11 09:44:22.999 76,66,73,40,6F,70,65,6E,73,73,68,2E,63,6F,6D,00,00,00,01,32,00,00,00,14,68,
< 2018-12-11 09:44:22.999 61,72,64,6C,69,6E,6B,40,6F,70,65,6E,73,73,68,2E,63,6F,6D,00,00,00,01,31,00,
< 2018-12-11 09:44:22.999 00,00,11,66,73,79,6E,63,40,6F,70,65,6E,73,73,68,2E,63,6F,6D,00,00,00,01,31,
. 2018-12-11 09:44:22.999 SFTP version 3 negotiated.
. 2018-12-11 09:44:22.999 Unknown server extension posix-rename@openssh.com="1"
. 2018-12-11 09:44:22.999 Supports statvfs@openssh.com extension version "2"
. 2018-12-11 09:44:22.999 Unknown server extension fstatvfs@openssh.com="2"
. 2018-12-11 09:44:22.999 Supports hardlink@openssh.com extension version "1"
. 2018-12-11 09:44:22.999 Unknown server extension fsync@openssh.com="1"
. 2018-12-11 09:44:22.999 We believe the server has signed timestamps bug
. 2018-12-11 09:44:22.999 We will use UTF-8 strings until server sends an invalid UTF-8 string as with SFTP version 3 and older UTF-8 strings are not mandatory
. 2018-12-11 09:44:22.999 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2018-12-11 09:44:22.999 Changing directory to "/".
. 2018-12-11 09:44:22.999 Getting real path for '/'
> 2018-12-11 09:44:22.999 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
> 2018-12-11 09:44:22.999 10,00,00,00,10,00,00,00,01,2F,
. 2018-12-11 09:44:22.999 Sent 14 bytes
. 2018-12-11 09:44:22.999 Received 33 bytes (0)
. 2018-12-11 09:44:22.999 Read 4 bytes (29 pending)
. 2018-12-11 09:44:22.999 Read 29 bytes (0 pending)
< 2018-12-11 09:44:22.999 Type: SSH_FXP_STATUS, Size: 29, Number: 16
< 2018-12-11 09:44:22.999 65,00,00,00,10,00,00,00,02,00,00,00,0C,4E,6F,20,73,75,63,68,20,66,69,6C,65,
< 2018-12-11 09:44:22.999 00,00,00,00,
< 2018-12-11 09:44:22.999 Status code: 2, Message: 16, Server: No such file, Language:
* 2018-12-11 09:44:22.999 (ECommand) Error changing directory to '/'.
* 2018-12-11 09:44:22.999 Cannot get real path for '/'.
* 2018-12-11 09:44:22.999 No such file or directory.
* 2018-12-11 09:44:22.999 Error code: 2
* 2018-12-11 09:44:22.999 Error message from server: No such file
. 2018-12-11 09:44:23.999 Session upkeep
. 2018-12-11 09:44:23.999 Looking for network events
. 2018-12-11 09:44:23.999 Timeout waiting for network events
. 2018-12-11 09:44:24.985 Getting current directory name.
. 2018-12-11 09:44:24.985 Getting real path for '.'
> 2018-12-11 09:44:24.985 Type: SSH_FXP_REALPATH, Size: 10, Number: 272
> 2018-12-11 09:44:24.985 10,00,00,01,10,00,00,00,01,2E,
. 2018-12-11 09:44:24.985 Sent 14 bytes
. 2018-12-11 09:44:24.985 There are 0 bytes remaining in the send buffer
. 2018-12-11 09:44:24.985 Looking for network events
. 2018-12-11 09:44:24.985 Timeout waiting for network events
. 2018-12-11 09:44:24.985 Waiting for another 4 bytes
. 2018-12-11 09:44:24.985 Looking for incoming data
. 2018-12-11 09:44:24.985 Detected network event
. 2018-12-11 09:44:24.985 Enumerating network events for socket 1172
. 2018-12-11 09:44:24.985 Enumerated 1 network events making 1 cumulative events for socket 1172
. 2018-12-11 09:44:24.985 Handling network read event on socket 1172 with error 0
. 2018-12-11 09:44:24.985 Received 33 bytes (0)
. 2018-12-11 09:44:24.985 Read 4 bytes (29 pending)
. 2018-12-11 09:44:24.985 Read 29 bytes (0 pending)
< 2018-12-11 09:44:24.985 Type: SSH_FXP_STATUS, Size: 29, Number: 272
< 2018-12-11 09:44:24.985 65,00,00,01,10,00,00,00,02,00,00,00,0C,4E,6F,20,73,75,63,68,20,66,69,6C,65,
< 2018-12-11 09:44:24.985 00,00,00,00,
< 2018-12-11 09:44:24.985 Status code: 2, Message: 272, Server: No such file, Language:
* 2018-12-11 09:44:24.985 (ECommand) Error getting name of current remote directory.
* 2018-12-11 09:44:24.985 Cannot get real path for '.'.
* 2018-12-11 09:44:24.985 No such file or directory.
* 2018-12-11 09:44:24.985 Error code: 2
* 2018-12-11 09:44:24.985 Error message from server: No such file
. 2018-12-11 09:44:24.985 Session upkeep
. 2018-12-11 09:44:25.891 Session upkeep
. 2018-12-11 09:44:25.891 Looking for network events
. 2018-12-11 09:44:25.891 Timeout waiting for network events
. 2018-12-11 09:44:25.907 Getting current directory name.
. 2018-12-11 09:44:25.907 Getting real path for '.'
> 2018-12-11 09:44:25.907 Type: SSH_FXP_REALPATH, Size: 10, Number: 528
> 2018-12-11 09:44:25.907 10,00,00,02,10,00,00,00,01,2E,
. 2018-12-11 09:44:25.907 Sent 14 bytes
. 2018-12-11 09:44:25.907 There are 0 bytes remaining in the send buffer
. 2018-12-11 09:44:25.907 Looking for network events
. 2018-12-11 09:44:25.907 Timeout waiting for network events
. 2018-12-11 09:44:25.907 Waiting for another 4 bytes
. 2018-12-11 09:44:25.907 Looking for incoming data
. 2018-12-11 09:44:25.907 Detected network event
. 2018-12-11 09:44:25.907 Enumerating network events for socket 1172
. 2018-12-11 09:44:25.907 Enumerated 1 network events making 1 cumulative events for socket 1172
. 2018-12-11 09:44:25.907 Handling network read event on socket 1172 with error 0
. 2018-12-11 09:44:25.907 Received 33 bytes (0)
. 2018-12-11 09:44:25.907 Read 4 bytes (29 pending)
. 2018-12-11 09:44:25.907 Read 29 bytes (0 pending)
< 2018-12-11 09:44:25.907 Type: SSH_FXP_STATUS, Size: 29, Number: 528
< 2018-12-11 09:44:25.907 65,00,00,02,10,00,00,00,02,00,00,00,0C,4E,6F,20,73,75,63,68,20,66,69,6C,65,
< 2018-12-11 09:44:25.907 00,00,00,00,
< 2018-12-11 09:44:25.907 Status code: 2, Message: 528, Server: No such file, Language:
* 2018-12-11 09:44:25.907 (ECommand) Error getting name of current remote directory.
* 2018-12-11 09:44:25.907 Cannot get real path for '.'.
* 2018-12-11 09:44:25.907 No such file or directory.
* 2018-12-11 09:44:25.907 Error code: 2
* 2018-12-11 09:44:25.907 Error message from server: No such file
. 2018-12-11 09:44:26.911 Session upkeep
. 2018-12-11 09:44:26.911 Looking for network events
. 2018-12-11 09:44:26.911 Timeout waiting for network events
bpbiszkopt
Re: Cannot get real path for '.'.
Can you login with any other SFTP client? Or even SSH terminal?
Server is configured to only sftp connection, ssh goes but it's dropped.
As I wrote earlier if I turn off chroot directory connection is successful.
I tried filezilla but it also fails.
I don't understand this error, what is mean "cannot get real path" error 2, wrong chmod/chown?
I don't see anything weird in ssh log.
I do not know, what is the root cause for the problem. You better ask on some server-related site. Like Super User or Server Fault.
