SFTP connection not working when we use script option
I am using WINSCP 5.13 and Windows 10.
I tried to connect SFTP in command prompt like following. "open sftp://****@**.***.**.** -privatekey="W:\Private.ppk" -passphrase=****" after getting in to WINSCP. It is working fine.
I tried the same using a script file like """C:\Program Files (x86)\WinSCP\WinSCP.exe" /ini=nul /script="W:\SendFileCommands.txt".
File has the following script "open sftp://****@**.***.**.** -privatekey="W:\Private.ppk" -passphrase=****".
When I run using script, is is failing to authenticate and expects the Hostkey.
May I know why it requires host key while we try to run the same using script?
Could you please give me the solution for this?
