SSL3 alert write: fatal: bad record mac
pathi
Hi Martin,
We are having these from past 1 week. As per your message I am sending log to your mail.
1.
TLS connection established. Waiting for welcome message...
Connection failed.
Using TLSv1.2, cipher TLSv1/SSLv3: ECDHE-RSA-AES256-SHA384, 2048 bit RSA, ECDHE-RSA-AES256-SHA384 TLSv1.2 Kx=ECDH Au=RSA Enc=AES(256) Mac=SHA384
Disconnected from server
Connection failed.
2.
decryption failed or bad record mac
(A)bort, (R)econnect (0 s): Reconnect
3.
Lost connection.
Connecting to <IP_of_server> ... not to be published: Connecting to 52.21.231.180 ...
Thank you,
pathi
Re: SSL3 alert write: fatal: bad record mac
Does the problem happens for every upload? Can you upload the files using any other FTP client?
pathi
Hi Martin,
Today I will try with another client and let you know.
No, not for all the files but 15%.
Even with WinSCP GUI and get also.
Thank you,
pathi
pathi
Hi Martin,
We got additional errors with the previously associated error,
2.SSL3 alert write: fatal: bad record mac
a. Server does not send proper UTF-8, falling back to local charset
b. TLS connect: error in SSLv3 read finished A
Can't establish TLS connection
Thank you
pathi
pathi wrote:
Tried with other FTP client. Able to upload and download without any issues.
Please post its verbose log file (showing upload of enough files to reproduce the problem with WinSCP).
