backup files on remote with monitored synchronization
imthenachoman
Is it possible to get WinSCP to make a backup of a file on a remote when doing syncing? For example, if a file that exists locally and on the remote is updated locally, then before WinSCP updates the remote file it would make a backup.
Let us say I had this:
local:
    /path/to/file.txt
remote:
    /path/to/file.txt
And I make an update to the file locally, then after the sync it should end up like this:
local:
    /path/to/file.txt
remote:
    /path/to/file.txt
    /path/to/file.txt.20181221032003.001
Or something like it....
imthenachoman wrote:
Thanks. Is it possible to recreate the folder structure in the recycle bin and/or use date/time in recycle bin folder so it'll create a new recycle bin folder for each day?
No, this is not supported.
