Directory Tree position issue
kyari
Hi I recently upgraded my WinSCP client. Before upgrading, I had my directory tree above my files panel, just the way I like it. But now after the upgrade the tree is stuck on the left side and I can't find the option to move it above, back to the way it used to be.
Does this feature still exist or was it removed?
kyari
Re: Directory Tree position issue
kyari
Sorry my mistake, was just confused by the settings wording.
- kyari
