My batch file for WinSCP only works with the hostkey but not with the privatekey
                @echo off
/log="D:\CoinFTP\Logs\Practifi_Logs\Log.txt" /ini=nul ^
/command ^
"open sftp://johnb@revex.com.au@ftp.hostedftp.com/ -privatekey=""D:\CoinFTP\KeyFiles\Practifi_PrivateKeyFile.ppk""" ^
"put -nopreservetime D:\CoinFTP\Data\Practifi\*" ^
"exit"
if %WINSCP_RESULT% equ 0 (
echo Success
cmd /c move /Y D:\CoinFTP\Data\Practifi\*.* D:\CoinFTP\Backup\Practifi_Backups
) else (
echo Error
exit /b %WINSCP_RESULT%
/command ^
"exit"
echo Success
) else (
echo Error
