Can i configure .filepart with something else like .tmp when automatic transfer resume is enabled
kiranbathineni
bangalore
With SFTP protocol, when automatic transfer resume is enabled, WinSCP first uploads the file to a temporary file with .filepart extension. Only after the transfer is completed the file is renamed to its actual name.
Will winscp support changing/configuring ".filepart" with ".tmp" etc?
For eg: i'm uploading a file abc.pdf winscp first adds abc.pdf.filepart as temporary file and then renames to abc.pdf once uploaded succesfully. Instead can i confgure in such a way temorary file name would be "abc.pdf.tmp" instead of "abc.pdf.filepart"
Please correct me if my understanding is wrong.
Re: Can i configure .filepart with something else like .tmp when automatic transfer resume is enabled
WinSCP does not support this.
What is your use case? How would changing the extension help you?
