Command SYNCHRONIZE not implemented'synchronize' is not recognized as an internal or external comman
SolarDAS
Hello All,
I have been using a script to synchronize a few local & remote directories using a batch file. The file worked for several days & now this afternoon I get an error"'synchronize' is not recognized as an internal or external command,operable program or batch file.". Also, If I attempt to run the Command within WinSCP, I get the following error " Command SYNCHRONIZE not implemented".
All your help is appreciated.
Re: Command SYNCHRONIZE not implemented'synchronize' is not recognized as an internal or external comman
