Writing a scripts to send new files since last session
Vee87
Dublin
I am looking to create a batch file for running a scheduled transfer using WinSCP 3 times a day.
The time I want to run are 1pm, 6pm and 9.30pm.
My initial idea was to have the script scan the folder and transfer anything older than 5 hours..
Script I have is this (from commands):
    "open ftp://USER:PASS1@123.123.123.123/" ^
    "lcd C:\Users\TEST\TEST" ^
    "put *.CSV<5HS" ^
I keep getting error – access denied, cannot copy file etc. I have tried a space between the *.CSV and the time operator, tried it with and without extra quotation marks but I'm not getting anywhere.
It will work without the time constraints no problem.
I was trying to find an answer on the KBs but no avail.
I've also seen the following guide on Remembering the last timestamp which would be really appealing if I could get it to work but it's beyond me at the moment!
How do I transfer new/modified files only?
Any help would be greatly appreciated.
Vee
Re: Writing a scripts to send new files since last session
Are you aware that the S suffix is supported by the latest beta version of WinSCP only?
Vee87
Dublin
Hi Martin,
I'm using 5.14.4RC.
I have removed the S and still getting errors. Am I right in using it this way?
"put "*.csv" <H"  ^
No. Just remove the S from your code. This is correct:
"put *.CSV<5H" ^
If it does not help, we need to see a session log file.
shaileshjs1@...
Access Deny Error
Check with recipient infrastructure team. They might have not given write permission.
