VSCode not working anymore as external editor
Morgy
Germany
since the release of VSCode 1.31.1 I cannot use it as external editor anymore.
Of course I asked them for help first, but it seems that we need some help here.
Ref: https://github.com/Microsoft/vscode/issues/68057
The weird thing is that it doesn't work while pointing it directly to the .exe (or using "associated application"), but running something like
"C:\Users\morgy\AppData\Local\Programs\Microsoft VS Code\Code.exe" C:\Users\morgy\AppData\Local\Temp\scp21773\var\www\vhosts\domain.com\index.php
via cmd works like a charm.
So maybe one could describe how external programs are opened exactly so the vscode team can figure out what's wrong here?
Re: VSCode not working anymore as external editor
I was not able to reproduce the problem. It works for me with 1.31.1.
Do you have 32-bit or 64-bit installation of VSCode?
Morgy
Germany
That's weird. People over at vscode say it might be a broken installation, but I reinstalled it already. =/
I'm using the 64-bit version.
Morgy
Germany
Thanks for reply.
I'm just curious – are you using WinSCP via Microsoft Store or installed manually?
Because I am using the Microsoft Store one.
I have tried Store installation now. And it also works just fine.
Did you on the other hand test it with a normal installation of WinSCP?
