Pending update/scripting
kb19
Good Morning,
I had a weird experience the other day and I am hoping to get some insight if this is normal behavior or not. I use scripts to automate using winscp and it would not work until an available update was installed. Is it normal behavior to stop the functionality of winscp until an update is installed, or should it work regardless? What are my options for stopping updates or automating updates?
Re: Update
This is definitely not something WinSCP does on its own.
You may have some smart firewall that blocks a network access for outdated software.
Though "would not work" is vague. What was the exact reason for the connection not being allowed? Did you check a log file?
