Help - Upload of file XXX' was successful, but error occurred while setting the permissions a
Setting up this new FTP and after reading the blog, I disabled the resume under Endurance and unchecked set timestamp and ignore permission errors is checked.
Please advise on next steps. Here is the log
2-18 11:28:22.299 --------------------------------------------------------------------------
. 2019-02-18 11:28:22.299 WinSCP Version 5.13.4 (Build 8731) (OS 6.3.9600 - Windows Server 2012 R2 Standard)
. 2019-02-18 11:28:22.299 Configuration: nul
. 2019-02-18 11:28:22.299 Log level: Normal
. 2019-02-18 11:28:22.299 Local account: MLBFL\tamara.yntema
. 2019-02-18 11:28:22.299 Working directory: C:\Program Files (x86)\WinSCP
. 2019-02-18 11:28:22.299 Process ID: 4172
. 2019-02-18 11:28:22.299 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe" /console=5.13.4 /consoleinstance=_3256_790 "/log=C:\ssis\UB\WinSCP.log" "/ini=nul" "/command" "open sftp://melbourne195%24:***@Transfer.IntuitionSystems.com/ -hostkey=""ssh-rsa 1024 ml+a4ZsKvcdkg3OruseJ0Ui92lqULPPwNVQLHZQ1dx8=""" "lcd C:\ssis" "cd /" "put UBEXPORT" "exit"
. 2019-02-18 11:28:22.299 Time zone: Current: GMT-5, Standard: GMT-5 (Eastern Standard Time), DST: GMT-4 (Eastern Daylight Time), DST Start: 3/10/2019, DST End: 11/3/2019
. 2019-02-18 11:28:22.299 Login time: Monday, February 18, 2019 11:28:22 AM
. 2019-02-18 11:28:22.299 --------------------------------------------------------------------------
. 2019-02-18 11:28:22.299 Script: Retrospectively logging previous script records:
> 2019-02-18 11:28:22.299 Script: open sftp://melbourne195%24:***@Transfer.IntuitionSystems.com/ -hostkey="ssh-rsa 1024 ml+a4ZsKvcdkg3OruseJ0Ui92lqULPPwNVQLHZQ1dx8="
. 2019-02-18 11:28:22.299 Session name: melbourne195$@Transfer.IntuitionSystems.com (Ad-Hoc site)
. 2019-02-18 11:28:22.299 Host name: Transfer.IntuitionSystems.com (Port: 22)
. 2019-02-18 11:28:22.299 User name: melbourne195$ (Password: Yes, Key file: No, Passphrase: No)
. 2019-02-18 11:28:22.299 Tunnel: No
. 2019-02-18 11:28:22.299 Transfer Protocol: SFTP
. 2019-02-18 11:28:22.299 Ping type: Off, Ping interval: 30 sec; Timeout: 15 sec
. 2019-02-18 11:28:22.299 Disable Nagle: No
. 2019-02-18 11:28:22.299 Proxy: None
. 2019-02-18 11:28:22.299 Send buffer: 262144
. 2019-02-18 11:28:22.299 SSH protocol version: 2; Compression: No
. 2019-02-18 11:28:22.299 Bypass authentication: No
. 2019-02-18 11:28:22.299 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: Yes
. 2019-02-18 11:28:22.299 GSSAPI: Forwarding: No; Libs: gssapi32,sspi,custom; Custom:
. 2019-02-18 11:28:22.299 Ciphers: aes,chacha20,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2019-02-18 11:28:22.299 KEX: ecdh,dh-gex-sha1,dh-group14-sha1,rsa,WARN,dh-group1-sha1
. 2019-02-18 11:28:22.299 SSH Bugs: Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto
. 2019-02-18 11:28:22.299 Simple channel: Yes
. 2019-02-18 11:28:22.299 Return code variable: Autodetect; Lookup user groups: Auto
. 2019-02-18 11:28:22.299 Shell: default
. 2019-02-18 11:28:22.299 EOL: LF, UTF: Auto
. 2019-02-18 11:28:22.299 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes; Follow directory symlinks: No
. 2019-02-18 11:28:22.299 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2019-02-18 11:28:22.299 SFTP Bugs: Auto,Auto
. 2019-02-18 11:28:22.299 SFTP Server: default
. 2019-02-18 11:28:22.299 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2019-02-18 11:28:22.299 Cache directory changes: Yes, Permanent: Yes
. 2019-02-18 11:28:22.299 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2019-02-18 11:28:22.299 DST mode: Unix
. 2019-02-18 11:28:22.299 Looking up host "XXX" for SSH connection
. 2019-02-18 11:28:22.299 Connecting to 199.227.218.200 port 22
. 2019-02-18 11:28:22.315 We claim version: SSH-2.0-WinSCP_release_5.13.4
. 2019-02-18 11:28:22.315 Server version: SSH-2.0-0
. 2019-02-18 11:28:22.315 Using SSH protocol version 2
. 2019-02-18 11:28:22.315 Have a known host key of type rsa2
. 2019-02-18 11:28:22.331 Using Diffie-Hellman with standard group "group14"
. 2019-02-18 11:28:22.331 Doing Diffie-Hellman key exchange with hash SHA-1
. 2019-02-18 11:28:22.487 Server also has ssh-dss host key, but we don't know it
. 2019-02-18 11:28:22.487 Host key fingerprint is:
. 2019-02-18 11:28:22.487 ssh-rsa 1024 95:6c:3f:9b:89:70:c8:13:12:ab:a4:d5:11:82:5a:0c ml+a4ZsKvcdkg3OruseJ0Ui92lqULPPwNVQLHZQ1dx8=
. 2019-02-18 11:28:22.487 Host key matches configured key
. 2019-02-18 11:28:22.487 Initialised AES-256 SDCTR client->server encryption
. 2019-02-18 11:28:22.487 Initialised HMAC-SHA1 client->server MAC algorithm
. 2019-02-18 11:28:22.487 Initialised AES-256 SDCTR server->client encryption
. 2019-02-18 11:28:22.487 Initialised HMAC-SHA1 server->client MAC algorithm
! 2019-02-18 11:28:22.518 Using username "XXX".
. 2019-02-18 11:28:22.565 Server offered these authentication methods: publickey,password
. 2019-02-18 11:28:22.565 Prompt (password, "SSH password", <no instructions>, "&Password: ")
. 2019-02-18 11:28:22.565 Using stored password.
. 2019-02-18 11:28:22.565 Sent password
. 2019-02-18 11:28:22.581 Access granted
. 2019-02-18 11:28:22.581 Opening session as main channel
. 2019-02-18 11:28:22.581 Opened main channel
. 2019-02-18 11:28:22.627 Started a shell/command
. 2019-02-18 11:28:22.627 --------------------------------------------------------------------------
. 2019-02-18 11:28:22.627 Using SFTP protocol.
. 2019-02-18 11:28:22.627 Doing startup conversation with host.
> 2019-02-18 11:28:22.627 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2019-02-18 11:28:22.627 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2019-02-18 11:28:22.627 SFTP version 4 negotiated.
. 2019-02-18 11:28:22.627 We will use UTF-8 strings as it is mandatory with SFTP version 4 and newer
. 2019-02-18 11:28:22.627 Getting current directory name.
. 2019-02-18 11:28:22.627 Getting real path for '.'
> 2019-02-18 11:28:22.627 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2019-02-18 11:28:22.674 Type: SSH_FXP_NAME, Size: 23, Number: 16
. 2019-02-18 11:28:22.674 Real path is '/'
. 2019-02-18 11:28:22.674 Startup conversation with host finished.
< 2019-02-18 11:28:22.674 Script: Active session: [1] melbourne195$@Transfer.IntuitionSystems.com
> 2019-02-18 11:28:22.690 Script: lcd C:\ssis
< 2019-02-18 11:28:22.690 Script: C:\ssis
> 2019-02-18 11:28:22.690 Script: cd /
. 2019-02-18 11:28:22.690 Changing directory to "/".
. 2019-02-18 11:28:22.690 Getting real path for '/'
> 2019-02-18 11:28:22.690 Type: SSH_FXP_REALPATH, Size: 10, Number: 272
< 2019-02-18 11:28:22.690 Type: SSH_FXP_NAME, Size: 23, Number: 272
. 2019-02-18 11:28:22.690 Real path is '/'
. 2019-02-18 11:28:22.690 Trying to open directory "/".
> 2019-02-18 11:28:22.690 Type: SSH_FXP_LSTAT, Size: 14, Number: 519
< 2019-02-18 11:28:22.706 Type: SSH_FXP_ATTRS, Size: 38, Number: 519
. 2019-02-18 11:28:22.706 Getting current directory name.
< 2019-02-18 11:28:22.706 Script: /
> 2019-02-18 11:28:22.706 Script: put UBEXPORT
. 2019-02-18 11:28:22.706 Copying 1 files/directories to remote directory "/" - total size: 4,740,755
. 2019-02-18 11:28:22.706 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: No; Mask:
. 2019-02-18 11:28:22.706 TM: B; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: No; InclM: ; ResumeL: 0
. 2019-02-18 11:28:22.706 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2019-02-18 11:28:22.706 Getting real path for '/'
> 2019-02-18 11:28:22.706 Type: SSH_FXP_REALPATH, Size: 10, Number: 784
< 2019-02-18 11:28:22.706 Type: SSH_FXP_NAME, Size: 23, Number: 784
. 2019-02-18 11:28:22.706 Real path is '/'
. 2019-02-18 11:28:22.706 File: 'UBEXPORT' [2019-02-16T00:50:38.201Z] [4740755]
. 2019-02-18 11:28:22.706 Copying "UBEXPORT" to remote directory started.
. 2019-02-18 11:28:22.706 Binary transfer mode selected.
. 2019-02-18 11:28:22.706 Checking existence of file.
> 2019-02-18 11:28:22.706 Type: SSH_FXP_LSTAT, Size: 22, Number: 1031
< 2019-02-18 11:28:22.721 Type: SSH_FXP_ATTRS, Size: 46, Number: 1031
. 2019-02-18 11:28:22.721 File exists: UBEXPORT;-;4740755;2019-02-18T16:22:40.000Z;3;"" [0];"" [0];rwxr-x---;0
. 2019-02-18 11:28:22.721 Checking existence of partially transferred file.
> 2019-02-18 11:28:22.721 Type: SSH_FXP_LSTAT, Size: 31, Number: 1287
< 2019-02-18 11:28:22.753 Type: SSH_FXP_STATUS, Size: 92, Number: 1287
< 2019-02-18 11:28:22.753 Status code: 2
. 2019-02-18 11:28:22.753 Opening remote file.
> 2019-02-18 11:28:22.753 Type: SSH_FXP_OPEN, Size: 44, Number: 1539
< 2019-02-18 11:28:22.753 Type: SSH_FXP_HANDLE, Size: 12, Number: 1539
> 2019-02-18 11:28:22.753 Type: SSH_FXP_WRITE, Size: 29996, Number: 2054
. 2019-02-18 11:28:23.268 311 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2019-02-18 11:28:23.268 Type: SSH_FXP_CLOSE, Size: 12, Number: 42756
< 2019-02-18 11:28:23.268 Type: SSH_FXP_STATUS, Size: 17, Number: 41222
< 2019-02-18 11:28:23.268 Status code: 0
< 2019-02-18 11:28:23.268 Type: SSH_FXP_STATUS, Size: 17, Number: 41478
< 2019-02-18 11:28:23.268 Type: SSH_FXP_STATUS, Size: 17, Number: 41734
< 2019-02-18 11:28:23.268 Type: SSH_FXP_STATUS, Size: 17, Number: 41990
< 2019-02-18 11:28:23.268 Type: SSH_FXP_STATUS, Size: 17, Number: 42246
< 2019-02-18 11:28:23.268 Type: SSH_FXP_STATUS, Size: 17, Number: 42502
< 2019-02-18 11:28:23.299 Type: SSH_FXP_STATUS, Size: 17, Number: 42756
< 2019-02-18 11:28:23.299 Status code: 0
> 2019-02-18 11:28:23.299 Type: SSH_FXP_REMOVE, Size: 18, Number: 43021
< 2019-02-18 11:28:23.299 Type: SSH_FXP_STATUS, Size: 17, Number: 43021
> 2019-02-18 11:28:23.299 Type: SSH_FXP_RENAME, Size: 40, Number: 43282
< 2019-02-18 11:28:23.331 Type: SSH_FXP_STATUS, Size: 17, Number: 43282
< 2019-02-18 11:28:23.331 Status code: 0
. 2019-02-18 11:28:23.346 Preserving timestamp [2019-02-16T00:50:38.000Z]
> 2019-02-18 11:28:23.346 Type: SSH_FXP_SETSTAT, Size: 35, Number: 1801
< 2019-02-18 11:28:23.346 Type: SSH_FXP_STATUS, Size: 44, Number: 1801
< 2019-02-18 11:28:23.346 Status code: 8, Message: 1801, Server: SSHServerAPI.SFTP.fxp_attrs, Language:
* 2019-02-18 11:28:23.346 (ETerminal) The server does not support the operation.
* 2019-02-18 11:28:23.346 Error code: 8
* 2019-02-18 11:28:23.346 Error message from server: SSHServerAPI.SFTP.fxp_attrs
. 2019-02-18 11:28:23.346 Asking user:
. 2019-02-18 11:28:23.346 **Upload of file 'UBEXPORT' was successful, but error occurred while setting the permissions and/or timestamp.**
. 2019-02-18 11:28:23.346 If the problem persists, turn off setting permissions or preserving timestamp. Alternatively you can turn on 'Ignore permission errors' option. ("The server does not support the operation.
. 2019-02-18 11:28:23.346 Error code: 8
. 2019-02-18 11:28:23.346 Error message from server: SSHServerAPI.SFTP.fxp_attrs")
< 2019-02-18 11:28:23.346 Script: Upload of file 'UBEXPORT' was successful, but error occurred while setting the permissions and/or timestamp.
< 2019-02-18 11:28:23.346 If the problem persists, turn off setting permissions or preserving timestamp. Alternatively you can turn on 'Ignore permission errors' option.
< 2019-02-18 11:28:23.346 Script: The server does not support the operation.
< 2019-02-18 11:28:23.346 Error code: 8
< 2019-02-18 11:28:23.346 Error message from server: SSHServerAPI.SFTP.fxp_attrs
* 2019-02-18 11:28:23.346 (ESkipFile) **Upload of file 'UBEXPORT' was successful, but error occurred while setting the permissions and/or timestamp.**
* 2019-02-18 11:28:23.346 If the problem persists, turn off setting permissions or preserving timestamp. Alternatively you can turn on 'Ignore permission errors' option.
* 2019-02-18 11:28:23.346 The server does not support the operation.
. 2019-02-18 11:28:23.346 Copying finished: Transferred: 4,740,755, Elapsed: 0:00:00, CPS: 7,930,611/s
. 2019-02-18 11:28:23.346 Script: Failed
. 2019-02-18 11:28:23.346 Script: Exit code: 1
. 2019-02-18 11:28:23.346 Closing connection.
. 2019-02-18 11:28:23.346 Sending special code: 12
. 2019-02-18 11:28:23.346 Sent EOF message
