File Mark (*.) is not working on 5.13.7
archana
nottingham
hello
i have a script which need to copy files from sftp which has no extension.
I have *. but it give me error
Bad message (badly formatted packet or protocol incompatibility).
Error code: 5
Error message from server: Bad message
batch abort
transfer binary
The transfer mode is default
please help
Re: File Mark (*.) is not working on 5.13.7
