How do I set up my dot net program to send files to server with multiple host key fingerprints?
jrmcjim
US
Martin,
I have a program that sends files to multiple sites that until now had a single fingerprint.
I now have a site that has an SHA-256 and MD5 fingerprint and I have not discovered how to set this up in my code.
Jim
jrmcjim
US
Thanks Martin. I finally understood (I think) what you referred me to and generated the stub to connect. Using the Host Key Fingerprint from the generated code, I received the following error:
SSH host key fingerprint "ssh-rsa 2048 1gqvgmbEUGYL+fKsHOMQrHmAtl3MflTavgKK6kIdl04=" does not match pattern /((ssh-rsa|ssh-dss|ssh-ed25519|ecdsa-sha2-nistp(256|384|521))( |-))?(\d+ )?([0-9a-f]{2}(:|-)){15}[0-9a-f]{2}(;((ssh-rsa|ssh-dss|ssh-ed25519|ecdsa-sha2-nistp(256|384|521))( |-))?(\d+ )?([0-9a-f]{2}(:|-)){15}[0-9a-f]{2})*/
Then your .NET program is using an old version of the WinSCP .NET assembly that didn't support SHA-256 fingerprints at all.
https://winscp.net/tracker/1589
Update to the latest version (preferred). Or use MD5 fingerprint.
