Solved: Only download files older than 2 minutes
Hello. I'm trying to setup a powershell script that will only download files that are older than the current time minus two minutes. When I run the script below it grabs all files regardless of their .LastWriteTime. Any help is appreciated.
This is just a snippet, not the full code.
param ( $localPath = "C:\Download\", $remoteDir = "/remote/path/", $remotePath = "/remote/path/*.xml" ) try { Write-Host "Trying connection..." $session.Open($sessionOptions) $earlier = (Get-Date).AddMinutes(-2) $directory = $session.ListDirectory($remoteDir) foreach ($fileInfo in $directory.Files) { if ($fileInfo.LastWriteTime -lt $earlier) { Write-Host $fileInfo.Name " will be downloaded" $transferResult = $session.GetFiles($remotePath, $localPath) foreach ($transfer in $transferResult.Transfers) { if ($transfer.Error -eq $Null) { Write-Host "Download of $($transfer.FileName) succeeded." } else { Write-Host "Download of $($transfer.FileName) failed: $($transfer.Error.Message)" } } } } }
