Waiting time before download starts
Evert
Netherlands
Hi all,
I like to use WINSCP for sharing software with my colleagues, everybody the same files in the same directories and it's organized on a QNAP NAS.
The whole Powershell script is build and works good when there is less data (4GB) on the NAS, when there is more data on the NAS it takes a long time before the sync is starting, like WINSCP is comparing / indexing both locations.
I've searched the forum, can't figure out how to fix my script that the sync is starter much quicker.
Below is my script, anyone who has a suggestion?
Thanks a lot, Evert
# Load WinSCP .NET assembly
Add-Type -Path "WinSCPnet.dll"
function FileTransferProgress
param($e)
Write-Progress `
-Activity "Download status" -Status ("{0:P0} Gedownload:" -f $e.OverallProgress) `
-PercentComplete ($e.OverallProgress * 100)
Write-Progress `
-Id 1 -Activity $e.FileName -Status ("{0:P0} Gedownload:" -f $e.FileProgress) `
-PercentComplete ($e.FileProgress * 100)
# Set up session options
Protocol = [WinSCP.Protocol]::FTP
HostName = "FTP SERVER"
PortNumber = 21
UserName = "USERNAME"
Password = "PASSWORD"
FtpSecure = [WinSCP.FtpSecure]::Explicit
TlsHostCertificateFingerprint = "2a:c7:b9:88:2a:d5:dd:ec:54:30:9b:3f:2b:87:25:a3:35:36:80:4e"
Timeout = new-timespan -minutes 5
try
# Will continuously report progress of transfer
$session.add_FileTransferProgress( { FileTransferProgress($_) } )
# Connect
# Download Files
$transferOptions.TransferMode = [WinSCP.TransferMode]::Binary
# Sync external to local
$synchronizationResult =
$session.SynchronizeDirectories(
[WinSCP.SynchronizationMode]::Local, "C:\Team-Software", "/Team", $True,
[WinSCP.SynchronizationCriteria]::Size)
# Downloadspeed
Write-Host "Downloaded file $remotePath to $localPath"
Write-Host ("Size {0:N0} KB, Time {1:hh\:mm\:ss}" -f $size, $duration)
Write-Host ("Speed {0:N0} KB/s" -f $speed)
# Throw on any error
$synchronizationResult.Check()
finally
$session.Dispose()
Re: Waiting time before download starts
Evert
Netherlands
Reply with logfiles
Hi Martin,
This reply contains one logfiles, from a session with both empty directories.
The other logfile I couldn't add, it can be downloaded from <invalid hyperlink removed by admin>
All sessions are done on a local WiFi network with the FTP server on a QNAP.
Best regards, Evert
Re: Reply with logfiles
It's the add_FileTransferProgress.
To calculate an operation progress for you, WinSCP has to first determine size of all files to be transferred. You have to chose. If you want the progress, you will have to bear the initial delay.
Evert
Netherlands
Thanks for your reply, I'm editing the code but there isn't any progress.
Can you tell me what code I have to edit / delete so the downlaod starts directly?
Kind regards, Evert
Delete $session.add_FileTransferProgress( { FileTransferProgress($_) } ) .
If it does not help, post a new log file (for a code with that line deleted).
