Close WinSCP if Access denied
Otto01
Hello together,
I'm using WinSCP to download some files automatically. Sometimes our partner change a password. So I get a Access denied.
At this case I have a little problem, because my software is still waiting, until WinSCP is finish and close the command window.
I call WinSCP with: MayPath\winscp.exe /console /script="MySkricpt.txt"
MyScript:
open ftp://XXX:XXX@XXX"
At this Point I got the "Access denied", and the WinSCP is trying again and again...
My qusetion: is there an option, to close WinSCP if I got an Access denied?
Many Thanks
Markus
(Of course I had read the Documents, and I have found no answer)
Re: Close WinSCP if Access denied
That's the expected behavior. Are you using the latest version of WinSCP?
Hello Martin,
thank you, for your prompt reply.
Before we use the version 5.6.2.0. Now I upgrade WinSCP to version 5.13.8.0.
At this newer version, WinSCP close automatically after "access denied".
Thank you Martin!
For the completeness, the log file:
. 2019-03-05 13:01:43.266 Connecting to XXX.XXX.XXX.XXX...
. 2019-03-05 13:01:43.282 Connected with XXX.XXX.XXX.XX. Waiting for welcome message...
< 2019-03-05 13:01:43.298 220 FTP server ready.
> 2019-03-05 13:01:43.298 USER XXXXXX
< 2019-03-05 13:01:43.313 331 Password required for XXXXX
> 2019-03-05 13:01:43.313 PASS ********
< 2019-03-05 13:01:45.360 530 Login incorrect.
. 2019-03-05 13:01:45.360 Connection failed.
. 2019-03-05 13:01:45.360 Password prompt (last login attempt failed)
