Issue connecting via SFTP to dropbox using Powershell
stwainer
Here
I'm successfil using the standard winSCP app in connecting and uploading files, but have issues connecting with the following code:
# Load WinSCP .NET assembly
Add-Type -Path "c:\Program Files (x86)\WinSCP\WinSCPnet.dll"
# Set up session options
    HostName = "dropbox.xxxx.com"
    UserName = "xxxxxx"
    Password = "xxxxxxx"
    SshHostKeyFingerprint = "xxxxxxxxxxx"
$sessionOptions.AddRawSettings("TryAgent", "0")
$sessionOptions.AddRawSettings("FSProtocol", "2")
Log file attached
The logs are from different machines. Can you use WinSCP GUI on the same machine that runs your code? With the same local account?
stwainer
Thanks for your help. Basically the SFTP receiver was limiting the IP's that could connect. I didn't realize that since it worked from *my* PC and thought it was a code issue.
Steve
