Error transferring file - No such file or folder. Syntax error in parameters or arguments.
Is there a simple method to correct this, so WinSCP looks at the file name as just a name?
See below some files names with "
Plus others that cause this error "Syntax error in parameters or arguments."
Source
% and numbers" cause WinSCP to interpenetrate it as /
%2f to /
Source
*_%2F9%5FVNE%2DJ_Index15970626.pdf ftp upload info *_/9%5FVNE%2DJ_Index15970626.pdf
Error transferring file '\\clenas01\abc_filegroup$\fg1\FILE GROUP 95\https___pam.cws-gr.com_audits-audTrans-print.cfm_%2F9%5FVNE%2DJ_Index15970626.pdf'.
https___pam.cws-gr.com_audits-audTrans-print.cfm_/9%5FVNE%2DJ_Index15970626.pdf: No such file or folder.
Error transferring file '\\clenas01\abc_filegroup$\fg1\FILE GROUP 95\https___pam.cws-gr.com_audits-auditReport.cfm_%2F%3C%24%3A%3DHJ_Index15965236.pdf'.
Error transferring file '\\clenas01\abc_filegroup$\fg1\FILE GROUP 95\https___pam.cws-gr.com_audits-audTrans-print.cfm_%2E%3C%24%3A%3_Index15968099.pdf'.
