Automated transfer of files not working
vineetarora
We had the automated process of putting files on the FTP server working till 03/08. We are using the session.PutFiles command in the vb.net program that run the automated process of transferring files everyday. We started doing this on 02/01 and only recently it appears to not work. This task is automated using the task scheduler, and the task is completing without any errors. However the file is not being uploaded. We are currently on the 5.13.8 version. Our systems appears to have been updated from the previous 5.13.7 version. It appears it stopped working right after the version update.
I am however able to upload the files manually using the user interface. But we want this to work automation.
Can anyone shed any light on this issue or have faced similar issues?
Re: Automated transfer of files not working
