Error in Log sudo: no tty present and no askpass program specified
I am trying to connect as root to clean install of ubuntu 16.10 LTS. I have amended the
If I change shell to
Paul
See below
etc/ssh/sshd_config to PermitRootLogin without-password. I can login using scp and shell set to default without problem.
sudo su - I get this error in log. Therefore can't login as root and edit files. In terminal I can sudo with a problem.
Paul
See below
Started a shell/command . 2019-03-20 10:55:26.545 -------------------------------------------------------------------------- . 2019-03-20 10:55:26.545 Using SCP protocol. . 2019-03-20 10:55:26.546 Doing startup conversation with host. . 2019-03-20 10:55:26.599 Skipping host startup message (if any). > 2019-03-20 10:55:26.599 echo "WinSCP: this is end-of-file:0" ! 2019-03-20 10:55:26.599 sudo: no tty present and no askpass program specified . 2019-03-20 10:55:28.553 Server sent command exit status 1 . 2019-03-20 10:55:28.554 Disconnected: All channels closed * 2019-03-20 10:55:28.614 (EFatal) **Connection has been unexpectedly closed.** Server sent command exit status 1. * 2019-03-20 10:55:28.614 Error skipping startup message. Your shell is probably incompatible with the application (BASH is recommended).
