Async GetFile
nighttrain
Poland
Async GetFile
Does WinScp has async methods? So far i do not see.
If not, did anyone tested it like putting OpenSession->GetFile-CloseSession into (C#)Task.Run ? Will it work fine with multiple task like that?
Edit:
I found this link doco: https://winscp.net/eng/docs/library_example_parallel_transfers
Question: why in dl you created one session for all Tasks but for upload you creating separated session in each task. is there really a diffrence?
Re: Async GetFile
There are no asynchronous methods in WinSCP .NET assembly.
You can use multiple instances of Session class in separate threads/tasks.
In the examples, there is a separate Session for each thread/task for both download (downloadSession) and upload (uploadSession). Please check the code again.
