transferOptions.AddRawSettings
I tried to use transfer options
Then I tried to use
instead but it seems to be ignored.
When I'm using corresponding option in transfer dialog box it seems to work fine.
Here is a C# code I'm using in SSIS:
Can you let me know what I'm doing wrong?
FileNameCase in transferOptions.AddRawSettings. And it looks like there is no kind of option in referenced .NET WinSCP assembly.
Then I tried to use
sessionOptions.AddRawSettings(@"Interface\CopyParam\FileNameCase", "2")
using System; using System.Data; using Microsoft.SqlServer.Dts.Runtime; using System.Windows.Forms; using WinSCP; namespace ST_6b06a4eeaec549698af87d29422e5606.csproj { [System.AddIn.AddIn("ScriptMain", Version = "1.0", Publisher = "", Description = "")] public partial class ScriptMain : Microsoft.SqlServer.Dts.Tasks.ScriptTask.VSTARTScriptObjectModelBase { #region VSTA generated code enum ScriptResults { Success = Microsoft.SqlServer.Dts.Runtime.Success, Failure = Microsoft.SqlServer.Dts.Runtime.Failure }; #endregion public void Main() { string winscpPath = @"C:\Program Files (x86)\WinSCP\winscp.exe"; //TEST string username = ""; string password = ""; string ftpSite = ""; string localPath = @"\\taphil-ww01\www\MSDSDocuments\USA_TEST\GM\"; string remoteFTPDirectory = "/opt/ops/data/non_edi/"; Boolean winSCPLog = true; string winSCPLogPath = localPath; SessionOptions sessionOptions = new SessionOptions { Protocol = Protocol.Ftp, HostName = ftpSite, UserName = username, Password = password, }; using (Session session = new Session()) { sessionOptions.AddRawSettings(@"Interface\CopyParam\FileNameCase", "2"); if (winSCPLog) { session.SessionLogPath = @winSCPLogPath + @"WinscpSessionLog.txt"; session.DebugLogPath = @winSCPLogPath + @"WinscpDebugLog.txt"; } // Connect session.Timeout = new TimeSpan(0, 2, 0); // two minutes session.Open(sessionOptions); TransferOptions transferOptions = new TransferOptions(); transferOptions.TransferMode = TransferMode.Binary; transferOptions.OverwriteMode = OverwriteMode.Overwrite; try { session.PutFiles(@localPath + "*.csv", @remoteFTPDirectory + "/feed/", false, transferOptions); } catch (Exception e) { Dts.Events.FireError(0, null,string.Format("Error when using WinSCP to download file: {0}", e), null, 0); Dts.TaskResult = (int).Failure; return; } session.Close(); } Dts.TaskResult = (int)ScriptResults.Success; } } }
