Trouble downloading filed modified in the past day
jwilkinson
Hello, I made a batch file to download files for one of our serves for the past day and put them in their own folder. But for some reason it is only downloading filed from 3/20 and before
Any ideas why that might be?
setlocal enableextensions
set datestr=%date:~-10,2%_%date:~7,2%_%date:~-4,4%
mkdir C:\Users\ipoffice\Desktop\Voicemail_VRL\%datestr%
C:\"Program Files (x86)"\WinSCP\WinSCP.exe /log="C:\Users\ipoffice\Desktop\winscp.log" /ini=nul /command "open sftp://Administrator:1p0ff!ce@192.168.2.5/ -hostkey=""ssh-rsa 2048 bi/MfOEaFH9KO4HvNACGKDADYp38EbXg4fPQsHnlV4U=""" "cd /opt/vmpro/MM/VRL" "lcd C:\Users\ipoffice\Desktop\Voicemail_VRL\%datestr%" "get -transfer=automatic -filemask=*<=1D -preservetime=all -neweronly *" "exit"
PAUSE
Re: Trouble downloading filed modified in the past day
