FTP Sync files to local folder
sameer12
Pakistan
Hello Experts!
I got the code from below link i think which works on SFTP . I am trying to work the code
sync ftp files to local directory . I have change the # Set up session options area and # Synchronize files area but finding an error
Error: Exception calling "Check" with "0" argument(s): "Error listing directory '/*.*'.
The filename, directory name, or volume label syntax is incorrect. "
https://winscp.net/eng/docs/library_session_synchronizedirectories
# Load WinSCP .NET assembly
Add-Type -Path "WinSCPnet.dll"
# Session.FileTransferred event handler
function FileTransferred
    param($e)
    if ($e.Error -eq $Null)
        Write-Host "Upload of $($e.FileName) succeeded"
    else
        Write-Host "Upload of $($e.FileName) failed: $($e.Error)"
    if ($e.Chmod -ne $Null)
        if ($e.Chmod.Error -eq $Null)
            Write-Host "Permissions of $($e.Chmod.FileName) set to $($e.Chmod.FilePermissions)"
        else
            Write-Host "Setting permissions of $($e.Chmod.FileName) failed: $($e.Chmod.Error)"
    else
        Write-Host "Permissions of $($e.Destination) kept with their defaults"
    if ($e.Touch -ne $Null)
        if ($e.Touch.Error -eq $Null)
            Write-Host "Timestamp of $($e.Touch.FileName) set to $($e.Touch.LastWriteTime)"
        else
            Write-Host "Setting timestamp of $($e.Touch.FileName) failed: $($e.Touch.Error)"
    else
        # This should never happen during "local to remote" synchronization
        Write-Host "Timestamp of $($e.Destination) kept with its default (current time)"
# Main script
try
    Protocol = [WinSCP.Protocol]::Ftp
    HostName = "***********"
    PortNumber = 21
    UserName = "**********"
    Password = "*****"
    FtpSecure = [WinSCP.FtpSecure]::Explicit
    TlsHostCertificateFingerprint = "5f:66:34:ad:e9:a9:8f:c2:60:79:d8:38:f6:da:7a:0b:69:d8:94:3C"
    try
        # Will continuously report progress of synchronization
        $session.add_FileTransferred( { FileTransferred($_) } )
        # Connect
        # Synchronize files
        $synchronizationResult = $session.SynchronizeDirectories(
            [WinSCP.SynchronizationMode]::Remote, "D:\FTP\", "/*.*", $False)
        # Throw on any error
        $synchronizationResult.Check()
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch
    exit 1
sameer12
Pakistan
Hello Experts
I am able to Synchronize files by changing the area # Synchronize files for local sync and remote sync only one part remaining.
I want write 2 files.
1. log files errors or succeded.
2. session information
       # Synchronize files
      [WinSCP.SynchronizationMode]::Local, "d:\FTP\Caspio", "/", $True, $False, 1, $TransferOptions)
       # Synchronize files
      [WinSCP.SynchronizationMode]::Remote, "d:\FTP\Caspio", "/", $True, $False, 1, $TransferOptions)
Re: FTP Sync files to local folder
I'm lost. Did you resolve the problem from your first post?
