Special characters in SFTP password (PowerShell)
Jimiboboyo
Hi
Have used the GUI to generate session code for PowerShell connection. The connection works in the GUI.
The password contains special characters.
I have enabled logging and the password being used is omitting the ' (apostrophe)
I have the password wrapped in double quotes
This doesn't seem like a normal apostrophe though it is slanted like maybe a grave accent or other.
How can I find out which character this is and force it to be included?
I tried using the URL tool to generate UTF-8 and this did the same thing
Regards
Jim
Re: Special characters in sftp password (powershell)
So what exact character is that? Can you paste it here? (or its Unicode code)
For what language did you generate the code?
jimiboboyo
Hi Martin
It is the following character I have pasted this in
I think it is identified as a grave accent from a UTF-8 website I established this
`   GRAVE ACCENT (U+0060)   60
I have tried to generate URL for password to then use the UTF-8 code in my PowerShell script and this character generates as %60 but I am unsure of the correct syntax.
Should the following syntax work?
    HostName = ""
    UserName = ""
    Password = "%60%50%30%20"   ##random utf-8 codes as example
    SshHostKeyFingerprint = ""
Jimiboboyo
I have resolved this it is a PowerShell issue not a WinSCP issue.
Just needed to wrap the password in single quotes for it to parse the backtick.
If using double quotes the backtick is omitted.
da_chicken
US
I ran into this issue today. The code generator in WinSCP 6.1.1 generates PowerShell code with double quotes. I happen to have a password with both a grave and a dollar sign in the password, and both of those are special characters with double-quoted string literals.
lb
backtick in password
I had a password with some slashes and a back tick. The slashes were automatically escaped but the backtick was deleted. Changing the whole password to be enclosed in single quotes instead of double quotes resolved the issue. Then it automatically escaped the slashes and the backtick.
Re: backtick in password
@lb: Can you post a screenshot showing the generated code with deleted backtick please? (and the password for which it happens)
