Command line synch hangs
danl
Australia
i synch files to a remote pc via command line with an external scheduler. latest winscp version used. ti's running via the command shell on a windows 10 box. tried both SFTP and secure webdav. Same result.
Used to be fine with previous versions.
It starts off great and then just seems to hang with no screen clues.
Also, any script command line to show verbose info?
Dan
Re: Command line synch hangs
