BUG: When connecting using SOCK proxy
proxyuser
When starting a Session using the command-line that uses a SOCKS proxy, when the SOCKS proxy closes the socket (because an error) the WinSCP crashes!
You can reproduce in this way: connect using PuTTY; enable SOCKS forward in the SSH session; open a session with WinSCP using the SOCKS proxy; kill the PuTTY session (without closing the PuTTY client)... this will end the TCP SOCKS connection, and WinSCP **crash**
Please, fix the bug!
Re: BUG: When connecting using SOCK proxy
Thanks for your report. Though I cannot reproduce the crash.
