timestamp from server part got truncated (only precise to minute level)
zcq0730
UKJ
I have encountered an issue with timestamp precision. (only precise to minute level)
After uploading files into the server, I found that the timestamp seems got truncated when I logged off the session and login again. The server is running an old fashion FTP protocol.
SFTP is not supported.
Details please see the attached Log file.
Sync_List_Checked_20190408.docx [2019-04-08T10:33:35.972Z] (Original)
Sync_List_Checked_20190408.docx [2019-04-08T10:33:00.000Z] (Server Part)
In brief, the server part lost the second timestamp information. (This happens only after logoff and re-login the FTP server, since WinSCP preserves the timestamp information during a session)
Is there a way to solve this problem? Where is the problem arise from? Due to settings or it is the problem with the server?
Many thanks in advance!
Description: Fraction of a Log file.
Reply with quote E-mail
Re: timestamp from server part got truncated (only precise to minute level)
zcq0730 wrote:
So the issue arose from our old fashion FTP server, right?
So there is no way to get the precise timestamp?
Yes, that's correct.
