All Scripts failing since upgrade to 5.15
rdavid2
WESTCHESTER, IL
Yesterday started getting messages about new version of WINSCP and I proceeded to upgrade WINSCP. Tested various sites with GUI with no problem. Then every automated job started failing. The first job I tested connected and got to the username and timed out. I tired a few things I found online and then discovered it was not bringing over the default directories.
I need to get the connections working in the automated scripts or do things manually until we find something that does work.
These scripts have been around for a few years now.
bob davidson
yucikala
Čáslav
I have problem with powershell after update
I upgrade to 5.15 from version before.
Now when I run powershell script, it failed.
# Load WinSCP .NET assembly
Add-Type -Path "C:\Program Files (x86)\WinSCP\WinSCPnet.dll"
Add-Type : Nelze načíst soubor nebo sestavení file:///C:\Program Files (x86)\WinSCP\WinSCPnet.dll nebo jeden z jejich závislých prvků. Toto sestavení je vytvořeno modulem runtime, který je novější než aktuálně zavedený modul runtime, a nelze je zavést.
At line:4 char:9
+ Add-Type <<<< -Path "C:\Program Files (x86)\WinSCP\WinSCPnet.dll"
+ CategoryInfo : NotSpecified: (:) [Add-Type], BadImageFormatException
+ FullyQualifiedErrorId : System.BadImageFormatException,Microsoft.PowerShell.Commands.AddTypeCommand
What's wrong now? Thanks
Re: I have problem with powershell after update
At line:4 char:9
Since 5.14, WinSCP .NET assembly requires .NET framework 4.
See https://winscp.net/eng/docs/incompatible_changes
yucikala
Čáslav
Whatever I have .NET 4 installed
Must be version 4.0? I have minimaly installed 4.7.2, 4.5.1, 4.6 a 4.6.1 - if I look to programs and functions. As you can see at attachment, my Visual studio has 4.0 framework...
May I some other parts install?
Re: Whatever I have .NET 4 installed
But your PowerShell loads an old version of .NET framework for some reason. What version of PowerShell do you have?
