synchro mask sftp
Nazer92
Ukraine
synchro mask sftp
Hello, i'm need help.
I'm trying to make automation to synchro with sftp
This is for downloading my locale files to sftp
option batch abort
open sftp://*
synchronize remote -criteria=time C:\IOC\ /ioc
how i'm can create mask for files like a xml,p7s, etc.
This is for downloading FROM sftp.
This part of script working good, for example :
===========The part for mask file only==============
get /ioc/NAMEFILE*.xml C:\IOC\*
so why i'm cant create script to downloading to sftp like this?
"synchronize remote -criteria=time C:\IOC\*.xml /ioc"
what i'm missed? How i'm can created mask for some files in one folder ?
2) question, how i'm can downloading files from sftp (like a MOVE) moving file out from sftp folder?
Sorry for my eng, if what :)
Re: synchro mask sftp
It should be:
"synchronize remote -criteria=time -filemask=*.xml C:\IOC /ioc"
I'm not sure I understand. Do you want to download and delete the file?
Nazer92
Ukraine
It should be:
Yes, downloading from SFTP, like a move. (downloading to locale disk, and delete from sftp)
Thank you!
