Changing folder based on date
Ondrej
Czech republic
I am facing to an issue with changing directory based on date.
My command is:
/log="D:\BATCHES\LOGS\CRE_WINSCP.log" /ini=nul ^
/command ^
"open sftp://....." ^
"cd /ucpex/P/eurex/%TIMESTAMP-1D#YYYYMMDD%/" ^
"get *XML.ZIP D:\BATCHES\TEMP_FILES" ^
"exit"
Unfortunately it absolutly ignores the part for changing directory based on date please log below:
. 2019-04-10 09:29:17.851 Startup conversation with host finished.
< 2019-04-10 09:29:17.851 Script: Active session: [1] 1059233_000002@193.29.90.132
> 2019-04-10 09:29:17.852 Script: cd /ucpex/P/eurex//
. 2019-04-10 09:29:17.852 Changing directory to "/ucpex/P/eurex//".
. 2019-04-10 09:29:17.852 Getting real path for '/ucpex/P/eurex//'
> 2019-04-10 09:29:17.852 Type: SSH_FXP_REALPATH, Size: 25, Number: 272
< 2019-04-10 09:29:17.879 Type: SSH_FXP_NAME, Size: 49, Number: 272
. 2019-04-10 09:29:17.880 Real path is '/ucpex/P/eurex'
. 2019-04-10 09:29:17.880 Trying to open directory "/ucpex/P/eurex".
> 2019-04-10 09:29:17.880 Type: SSH_FXP_LSTAT, Size: 23, Number: 519
< 2019-04-10 09:29:17.901 Type: SSH_FXP_ATTRS, Size: 37, Number: 519
. 2019-04-10 09:29:17.901 Getting current directory name.
< 2019-04-10 09:29:17.901 Script: /ucpex/P/eurex
> 2019-04-10 09:29:17.902 Script: get *XML.ZIP D:\BATCHES\TEMP_FILES
. 2019-04-10 09:29:17.902 Listing directory "/ucpex/P/eurex".
> 2019-04-10 09:29:17.902 Type: SSH_FXP_OPENDIR, Size: 23, Number: 779
< 2019-04-10 09:29:17.923 Type: SSH_FXP_HANDLE, Size: 13, Number: 779
> 2019-04-10 09:29:17.923 Type: SSH_FXP_READDIR, Size: 13, Number: 1036
< 2019-04-10 09:29:18.163 Type: SSH_FXP_NAME, Size: 2559, Number: 1036
> 2019-04-10 09:29:18.163 Type: SSH_FXP_READDIR, Size: 13, Number: 1292
< 2019-04-10 09:29:18.180 Type: SSH_FXP_STATUS, Size: 28, Number: 1292
< 2019-04-10 09:29:18.180 Status code: 1
> 2019-04-10 09:29:18.180 Type: SSH_FXP_CLOSE, Size: 13, Number: 1540
Could you advise me please?
Thank you in advance,
Ondrej
andres3626
Ecuador
Script creation
Good day. Could you tell me if the following is okay. Especially the issue of the date of a previous day. The files are called 20200811JODHOY.log and 20200811JODHOY.DMP and I want to copy them to daily, change the date of the previous day, so today I copy the files with yesterday's date. The script below is well created?
@echo off
open scp://suchas:random45@200.34.56.78/ -hostkey="ssh-rsa 2048 fG5h60iJKillL3YUlcZkcqQniqX1Pj="
cd /resp_expdp/DIARY_CH
get %TIMESTAMP-1D#yyyy-mm-dd%*.* d:\
if %WINSCP_RESULT% equ 0 (
echo Success
) else (
echo Error
exit /b %WINSCP_RESULT%
