Too many parameters for command 'open
nareshv
Hello, I am getting "Too many parameters for command 'open'." error when trying to connect to a server for below command,
open sftp://uname:pwd@abc.example.com/ -hostkey="ssh-rsa 1024 xx:xx:xx:xx:xx" -timeout=60 -rawsettings SendBuf=0 SshSimple=1 -rawtransfersettings IgnorePermErrors=0 PreserveTimeDirs=0
I have checked lot of other posts mentioning the use of Double-Quotes for text having space and I think my above script is complaint with that.
If I remove the last set of parameters followed by "-rawtransfersettings" my script work fine. That is the "open sftp://uname:pwd@abc.example.com/ -hostkey="ssh-rsa 1024 xx:xx:xx:xx:xx" -timeout=60 -rawsettings SendBuf=0 SshSimple=1" commands works perfectly.
I am not sure how to proceed further with this as I am new to command scripting world.
Regards,
Naresh
