Can't delete files and folders in Local Directory while Syncing to Remote
ET205
Hi, I've had this problem at least 4 times by now. There are a few directories that I have set to Sync with the "Keep remote directory up to date" option. If I try to delete files and/or folders using either Windows File Explorer or another session of WinSCP then some of them get deleted and others (randomly) don't and show an error saying either that I need permission from the Admin account(which I am logged in as) or that the file is in use by another process. The first error is more common. Now from what I understand, "Keep remote directory up to date" is supposed to check the local directory at intervals and update the remote directory when a change is found, not stop me from working with the local files! Help, please?
Re: Can't delete files and folders in Local Directory while Syncing to Remote
Do you really get the problem with files? Or with folders only?
