Tabbing through file list after upgrade
tt4mc
Before the most recent upgrade (April 2019) I was able to type the first letter of a file name and the file would be "pre-selected" / "highlighted" in the file list. If I repeated to press the same letter, the next file in alphabetical order beginning with that letter would be "pre-selected" ...
After the upgrade, I have to press the letter and then keep pressing tab in order to produce the same effect.
I am wondering if anyone knows what I can do to revert this functionality?
Re: Tabbing through file list after upgrade
tt4mc
Yes ... this does exactly what I want! Will this be an option in future releases?
Thanks for your feedback.
This change will be included in upcoming 5.15.3.
