Issues with Verify Checksum feature and with manually calculating checksum
snicholas
I am running into an issue when I attempt to use the "Verify Checksum" feature or when I navigate to the file/folder properties for the "Calculate checksum" feature while connected via SFTP. When attempting the "Verify Checksum" feature, the value for the local file is returned, but I get the following error:
"Error: Exception calling "CalculateFileChecksum" with "2" argument(s): "Operation not supported."
If I navigate to the properties of a file, and click on the Checksum tab, all options are grayed out.
If I try these same two processes while connected via FTP, they both work without issue. I only experience issues when connected via SFTP.
According to the vendor documentation for our SFTP server the algorithms SHA1, SHA256, SHA512, and MD5 are supported over SSH/SFTP.
If anyone has run into an issue like this, I'd appreciate any suggestions on resolving this problem.
Re: Issues with Verify Checksum feature and with manually calculating checksum
Most probably, the documentation is either wrong or you have misinterpreted it.
Isn't the documentation you refer to about SSH, rather than about SFTP? This is SFTP-only functionality. It has nothing to do with algorithms used by SSH.
Can you post a link?
