Print ACCELEATED HARDWARE ENCRYPTION connection
With the PuTTY 0.71 version, the HARDWARE ENCRYPTION ACCELERATION is supported. Then in the logs you can see if the encryption/hashing is using an Accelerated or an Unaccelerated implementation. It will be interesting if the same information will be available in the "Server and protocol information" Window of WinSCP.
Regards.
Regards.
