Delete file older than X days using file name
john111
Hi, im new in scripting. My purpose is want make a script that can delete file automatically for example (older than 2 month) but using file name because my file name already recorded as date
(XXXX_XX-MM-DD-YYYY-XXXXXXXX.zip) due my file modified date sometimes not correct.
Below are my script, can help me check what is the problem?
"C:\Program Files (x86)\WinSCP\WinSCP.com" /ini=nul /log="C:\Users\xxxx\xxxx\Log\ftp !M !D !Y.log" /command ^
    "open ftp://user:pass@example.com/" ^
    rm -filemask="*<30D=xxxx_xx-%TIMESTAMP#mm-dd-yyyy%-xxxxxxx.zip"
    "exit"
Re: Delete file older than X days using file name
You cannot select files older then certain timestamps by timestamp in their name using a simple file mask. You can only select all files for a specific date like:
rm XXXX_XX-%TIMESTAMP-30D#mm-dd-yyyy%-XXXXXXXX.zip
If you need to delete even files with older dates, you need to use PowerShell:
https://stackoverflow.com/q/49656000/850848
john111
that code works but i want to delete file for example older than 30day+
same function like
*<30D
The code that u give only delete folder older than 30days ONLY.
Please advise. Thanks
