Live enable/disable compression
I suggest to add one option to enable/disable compression when a session is stablished. This can be achieved by a Session Key re-exchange. This will be useful when you connect without compression (good default) and then you need to transmit some files that requires compression.
I hope you like to support this.
Thank you!
Thank you!
