more than one filemask error
Nardog
Virginia
I am trying to put files in a remote directory non-recursively as well as be less than a day old.
Filemask:
transferOptions8.FileMask = "*>=1D;|*/";
Full Code Block:
session8.Open(sessionOptions8);
                    TransferOptions transferOptions8 = new TransferOptions();
                    transferOptions8.TransferMode = TransferMode.Binary;
                    TransferOperationResult transferResult8;
                    transferResult8 =
                        session8.PutFiles(@"C:\Transmissions\Inbound\*", @"/from/ss/", false, transferOptions8);
                    transferResult8.Check();
The `Inbound` folder has folders in it I do not want want to send.
The error I get when running this is:
C:\>.\Sync.exe
Error: WinSCP.SessionRemoteException: Mask is invalid near '=1D;|*'.
at WinSCP.OperationResultBase.Check()
Any thoughts?
Re: more than one filemask error
The semicolon should not be there.
It should be:
transferOptions8.FileMask = "*>=1D|*/";
While technically the semicolon should be ignored, it's not as there's a bug:
https://winscp.net/tracker/1745
