Ignore folder structure when copying the files.
macservice123
hanoi
Is it possible to ignore local directory file structure when copying files?
Let's say we've got a couple of files in subdirectories as follows:
./testa00.txt
./testb00.txt
./01/testa01.txt
./01/testb01.txt
./02/testa02.txt
./02/testb02.txt
Is there a way to put those testa*.txt files on FTP server without copying the folder structure. Ideally, I would like all the files to be dropped into a single folder on the FTP server, is there a way to do it?
Cristiano
Re: Ignore folder structure when copying the files.
You can write a simple PowerShell script for that.
We have an example for download:
Downloading all files from FTP/SFTP to the same local folder
Upload would be similar.
Actually, this code will do what you want:
https://winscp.net/eng/docs/library_example_moves_files_keeping_directory_structure#upload_powershell
If you modify it to:
  1. replace $remoteFilePath with $remotePath in the $session.PutFiles call
  2. remove if (!($session.FileExists($remoteFilePath))) { $session.CreateDirectory($remoteFilePath) }
It's just unnecessarily complicated for your simpler needs.
On the other hand, it's prepared to be used as a WinSCP extension, so it can be installed into WinSCP GUI.
https://winscp.net/eng/docs/extension
For a simple code, see
WinSCP Script upload recursivelly all files matching a mask to the same folder
Rockwell
Hey Martin! I could load the extension into the WinSCP but can't figure how to run this to the actual synchronization.
