Connecting to multiple sites questions
I have a folder with multiple sites in it and noticed that in the details on the right it shows each site as user@site instead of the site name. If I click to login on the folder and it opens all of them, it shows the user@site instead of the name in the tab title, which makes it a little harder to navigate as I know the names better than the addresses. Is there a way to change that? I know I can open each individually and save a workspace, but I'd like to be able to work with folders if it's just a setting.
Also, any time I open multiple sites like that, it only connects to the visible one. Then as I click on each site I have to wait for it to connect. Is there a way to change that so they all connect at the same time?
Thanks!
Thanks!
