Deleting all empty folders using WinSCP
I'm using WinSCP through an SSIS task.
I'm want to delete all the empty directories in the sftp server, but it doesn't work.
My code :
Everything works, except the last line "rmdir *" that doesn't have any effect.
I tried to use "rm *<1M" to delete everything that is less than 1MB but it deleted everything in the directory, even if it weights more than 1MB.
Can someone help me with this problem ?
Thank you in advance, best regards.
Pretty.
My code :
winscp.StandardInput.WriteLine("open Sftp://" + UserFilesServer + "@" + FilesServer + ":" + WinSCPPort + " -privatekey=" + KeyFilesServer + " -passphrase=" + WinSCPPass);
winscp.StandardInput.WriteLine(" cd " + PathFilesServer);
winscp.StandardInput.WriteLine(" cd ../" + PathFilesServerEnvoi);
winscp.StandardInput.WriteLine("rmdir *");Everything works, except the last line "rmdir *" that doesn't have any effect.
Pretty.
