How use FTP with the TLS protocol
Arenas
France
Hello
Please,
I have never used WinSCP
and how include the TLS protocol and run with WinSCP?
[Net.ServicePointManager]::SecurityProtocol = [Net.SecurityProtocolType]::Tls
Thanks for your help
Arnold
The script is:
cls
$Xa = (Get-Host).UI.RawUI
$Xa.WindowTitle = "Sync Folder To Ftp"
$Xftp = "ftp://perso-ftp.orange.fr/"
# $Xftp.UsePassive = $true
# $Xftp.EnableTls = $true
$XlocalDirectory = Get-Content "c:\studio\"
$Xuser = "............."
$Xpass = "............."
$Xwebclient = New-Object System.Net.WebClient
$Xwebclient.Credentials = New-Object System.Net.NetworkCredential($Xuser,$Xpass)
$XFiles = Get-ChildItem -Path "c:\studio\*" -Rec -For | ? {$_.LastWriteTime -gt (Get-Date).AddHours(-1)} | where { ! $_.PSIsContainer } | Select-Object FullName
$Xnombre = $XFiles.Count
foreach ($XFile in $XFiles)
    $XLocalFile = $XFile.FullName
    $XRemoveDirectory = $XLocalFile.Replace("C:\studio\","")
    $XChangeSlashes = $XRemoveDirectory.Replace('\','/')
    $XRemoveSpaces = $XChangeSlashes.Trim()
    $XRemoteFile = $Xftp+$XRemoveSpaces
    $Xuri = New-Object System.Uri("$XRemoteFile")
    $Xwebclient.UploadFile($Xuri, $XLocalFile)
    Write-Host "Getting $XFile from $XlocalDirectory" -Foreground "Red" -BackgroundColor DarkBlue
    Write-Host "Puting $XFile to $Xftp" -Foreground "Yellow" -BackgroundColor DarkBlue
Write-Host "Finished Sync to $Xftp" -Foreground "Green" -BackgroundColor DarkBlue
$Xnombre.ToString() + " File sync -- END -- " + (Get-Date)
$Xtext1 = $Xnombre.tostring() + " File sync -- END -- " + (Get-Date)
Re: How us Ftp with the TSL protocol
I'm not sure I understand your question.
Your code does not use WinSCP.
Do you want to switch to WinSCP?
Arenas
France
Hello @Martin
Thanks for your reply
Yes I want switch to WinSCP
In order I would do
  1. Run the the task manager (PowerShell files)
  2. Run WinSCP to upload the update files
But WinSCP block the Task Manager.
Please how do?
Thanks Arnold
Arenas
France
Hello
The Suggestion is:
Protocol FTPES with TLS explicit port 21 to upload files.
With PowerShell:
cls
" 1"
Invoke-WebRequest "https://example.com/"
" 2"
" 3"
# get TSL !!!
[enum]::GetNames([Net.SecurityProtocolType])
" 4"
# Force PowerShell to use TLS 1.1
[System.Net.ServicePointManager]::SecurityProtocol = [System.Net.SecurityProtocolType]::Tls11
" 5"
# Force PowerShell to use it's default of TLS 1.0
Arnold
Arenas wrote:
The Sugestion is:
OK, I do not know why I've though that you asked for implicit.
So use FtpSecure.Explicit.
